View Full Version : Beginners
- 800 mm P51 Mustang Issues
- Plane ID please...
- God bless the people of Chile
- Ace Alpha 15 first flight problems
- R.I.P. Mustang
- Digital vs Analog Servos
- Supplier Service
- What Size Electric Motor
- servo arms
- Mini Brushless motor adapter?
- I need advise on a park flier
- Phoenix Strega flaps
- Saito 50 needle settings
- GWS Stick F with Blue Wonder Brushless
- HYDRO LINES
- Big Stik 60
- No RC flying this afternoon because....
- Combining digital & analog servos?
- Brown goop coming from the muffler?
- RPMS for a 55AX
- Ultra Sport ARF Chinese Clone
- Magnum xl .52 rfs, losing power in flight.
- Looking for beginner plane recommendations
- Buggs Bunny Airplane Brakes - Video
- Question about Radio
- hauling your planes to the field
- The Witch Project
- Carb on os 40 LA
- funtana 90
- Fuel line question....
- Anybody Flying a GP Super Sportster 40 Mkll ARF?
- Do I use Epoxy or medium CA
- Servo tray
- Sig Kadet Senior
- arf motor
- Receivers and Servos
- Ultimate 10-300 Goldberg
- Stupid beginner question #1703
- Bind a Futaba 7C to Spektrum AR6400
- Plane does not want to land
- Monitoring a real flight
- looking to slow my trainner down without a new engine?
- GEE BEE 751
- Parts for Dynam A-10
- bigger and heavier
- Trainer With Gas Engine
- OS 55 AX HELP!!!
- Servo Arm Help
- CA Technique With Servo Mounts
- Electric motors
- Dual Rate problems, a heads up for beginners, and old guys too
- I like Park Flyers!
- Dubro anti vibration Motor Mount
- Servo mounting isolation
- columbus Oh Flying fields
- Questions about old engine parts...
- how to calulate thurst
- False firewall
- work can be a pain
- os 120 ax
- buddy box set up
- Introducing someone to RC
- ASP engines with free shipping
- Biplane for OS 65 LA
- Push Rods
- making your own extensions
- Got my LT-40 completed
- Planes and Helis
- thunder tiger 46 pro factory settings
- Ailerons???
- Wing loading on a bipe
- CG and Throws for an ACE 4-40 Biplane
- Pushrod question
- Control your RC Plane with the computer
- Really, how imp is balancing your 12" prop?
- JR NER-700 6v?
- My first RC Plane. (PLZ help me build it)
- Tip on how to grind Kitty Litter to a fine powder
- Iowa State University Aerospace Engineering project
- What to use for fuelproofing
- BEST PLANE TO LEARN ON
- Maybe Someone here?
- $5 airplane
- Old trainer rebuilt, need help with ID
- For Ken or Mike YS Engine
- Radio Equipment Question
- OLD TRAINER
- Moving servos to the rear
- What is the purpose of the brake on the ESC for
- great planes cub engine size
- Rates for beginner
- Condor 40H
- DX6I Tx Functions
- what is aileron flutter?
- Winter Project
- combat with hawk
- Removing plane from a tree?
- A123 Battery Suggestions Please
- Newbie Dilemma
- Super Tigre Head
- My first crash. LT-25 with a OS FS .30
- Spectrum/ Hitec
- Soldering Iron Question
- 2 blade to three blade question
- ASSAULTED WHILE FLYING: a warning to all of you.
- questions bout old motors???
- gas leaking outa carb???
- Sig Kadet Mark II
- HOB P51 Candyman
- Prop size and thrust
- How do I do a listing for a swap or sale?
- seagull edge 540 servos
- os 744 muffler
- North American P 51 D mustang help
- Seagull edge 540
- magnum .91 question
- Evolution .52NX motor leak?
- begenner help setting up a triton 2 eg
- My first 27% gasser
- Dead sticks are ok
- Telemaster Engine
- transmitter receiver
- fuel tank setup problem
- Starting gear questions
- dead battery
- Servo (what to use)
- ar700 rx dx7 tx help
- Trainers
- engine quits
- Park Zone T-28 Trojan problems
- Webra .61...Fuel recomendations? Do i need a head shim??
- How Much Glue is too much?
- How Much Wind For Training?
- Balance Weight ?
- Wind is fun
- UHU Creativ glue vs. Hold the Foam
- Guillows SPITFIRE 504
- Repairing cracked canopy
- Which Camera to take
- Radio crystals on a budget
- spektrum radio from phoenix flight sim
- thunder tiger pros, help
- Top Flite P-51 1/7th Scale Build
- ya tengo mi entrenador
- Radio Expodental
- .52 Surpass on Avistar?
- balancing an ultra stick 40 with O.S. 61motor
- MPI Heavy duty switch
- Electric Plane Suggestions
- Jetman - RC Jet Powered Hang Glider
- First Mid Air
- Out for a while getting back in
- First Maiden Flight
- Glow/Gas model float planes
- Mid Air...need advise
- What low winger trainer I can buy??
- RTF Glow Trainers - Going the way of the Dodo?
- carbon build up - how to clean?
- Bypass surgery
- LT-40 Motor
- Mounting a switch/charging jack..
- ya gotta luv
- ready to fly!
- CMP P40 73"
- Best possible Redundancy
- Looking for plans
- frequency board design
- Joining Steel rod...How?
- starmax f1/8 64mm edf jet five servos
- shock absorbing engine mounts
- Newbie - Ailerons or Rudder?
- Cleaner for engine exterior
- Sig kadet senior
- No joy today!
- prop size for escapade
- New to the hobby
- RC Flight Simulator
- How bad is an unbalanced prop spinner hub?
- Where to buy fake bombs?
- 10% off at Horizon
- FUN THINGS TO DO WITH A TRAINER
- What are Flapperons???
- Buying Real Flight Second Hand???
- Hobbico Superstar EP Conversion
- Hobbico SuperStar EP Select Electric
- Unintentional Take off
- Hangar 9 ARF Quiality~Not
- la 40 too small
- Replacing Landing Gear
- Futaba S Bus rx with normal servos
- My plane has up trim in it, should I make it more tail heavy?
- LT-40/.46 LA and prop??
- What is the Max amperage for charging?
- Big thanks to the Simulator
- Downwind Turns!!
- training
- Back in hobby
- seagull edge 540 v2
- pinch test
- Down Angle On Motor?
- f27 stryker reciever
- DLE 20cc and Jba 15cc
- T606 Charger
- Help with fuel issue
- What to do
- Ailerons/hinge gapes covered, one piece.
- rebuild or not
- Thinking of getting this one.
- Looking for advice
- Hello From a Newbie
- rc landing gear.
- What diameter
- Want to learn (Newbie)
- Removing stuck needle set screw
- Help with foam wing!
- Best
- Lipo charger question
- Skis for duraplane trainer
- ora 4 in 1 transformer propulsion
- saludo me presento
- E-GO/ARTECH Cessna 182 Brushless 2.4ghz
- smoker kit??
- Will my old plane be good for anything?
- Pneumatic retract question
- Futaba
- My new hobbie :)
- engine stalls
- Sig LT-40 motor choices
- Is my wing going to be okay!?
- wing problem
- Top flite Cesna 182 skylane kit
- Phoenix Flight Simulator....Best investment BEFORE you fly!!!
- Super Tigre G90: help putting back together
- servo size?
- dang Rain
- RC Motors
- Corona Receiver & Crystals - The Scoop?
- Thanks for the advise guys!! Escapade is a great 2nd plane.
- NO SX
- OS 120AX: Bisson Pitts or Slimline Q series muffler?
- I need some advises and help from nitro pilots
- Helipal.com; any problems
- Teaching/plane selection for a child help
- four channel micro trainer
- HELP, Returning to the sport, to much new stuff out there!!!!
- engine problem
- Senior Telemaster~where?
- Super tigre 90
- Down she goes! Glue Anyone?
- What Planes are good?
