View Full Version : Beginners
- Finally, I cut the cord !!!!!
- JRcharge switch installation
- Avistar questions
- Recommended glow plug ignitor?
- aaaaaaaaaaaaaahhhhhhhhhhhhhh
- balsa wood types
- Soloed!
- Pusher-Prop Electric Trainer? V-Tail?
- Evolution .46 NT HP
- Fuel Proofing Wood?
- Breather on carburetor?
- How long will glow ignitor last before recharge?
- Dropped transmitter
- I'm new here, my solo story,,,
- graupner extra 300s or cap 232
- How to start engine with prop hub.
- Trainer pulls to the right on take-off?
- Videos/Pic LT-40
- aeileron set-up
- Covering with Monokote
- PAYLOADS
- Have three questions on engine adjustment
- Cleaning Tips After Flight
- Where do I buy this? Please help
- Fiberglass Tape???
- Couple of questions regarding my new LT 40
- fixing broken wing spars (actually ribs)
- Detachable servo wiring
- Wanted, recomendations for a slow trainer
- CA Hinge Disaster
- servo wiwing legnth
- Plane Turning
- Engine Incidence/ Engine Mount
- Futaba Server Tray
- How long to Solo?
- Prop balancing 101 - help!
- Lazy p-51 CG
- rudder control
- WARNING: if you own a tiger trainer read this post
- How much for used engine?
- RC shop in miami?
- I am the Krash King
- change of mode
- Where did they GO and How do I add a pic?
- Just like riding a bike (yeah right)!
- TumbleWatt HELP!!
- Sig Kadet LT-40 parts
- Great Planes PT electric
- Pro/Tech charger??
- Trim/Ailrons
- Test Flight Bennet Field, Las Vegas (help)
- I can't get my canopy clean.
- pull-pull rudder system
- High rates VS. Low rates
- ailerons design
- aileron control
- NEW GOLDBERG EAGLE 2 ARF TRAINER?
- CHECKING THE C.G. OF A NEW PLANE?
- Problem building my Great Planes PT-40
- Thank You All, I Soloed today!
- best way to taper edge
- Building a stronger wing
- IS UP trim down trim and down trim up trim?
- Cross-Wind.......Arghh
- Contender 60 engine recommendations
- Rascal 40 arf need help with parts...
- SIG Kadet LT-40 Build
- Sig Kadet LT-40
- \\\Cover My Wings Please///
- Barn Door aileron vs. Strip aileron
- Canopy turned dirty on me.
- Flaperons
- Stencils And Decals
- I am SOLO but landing is still bumpy
- Begginer please help!
- Boeing VS my design
- This site slow? Or is it my connection?
- Somethin Extra Engine Out
- Transition to Inverted?
- Building Time
- Flying Attitude (re: Airplane)
- Does trimming put stress on servos?
- Alpha trainer or Easy 2 trainer
- Props?
- Radio Repair/Check
- 2nd plane choice?
- Radio Question
- Common Newby mistakes when landing under windy conditions
- Most visible color and design schemes
- First complete build
- Rebel Hobbies in San Antonio
- Flight Sims
- good day at the field
- CA QUESTION......HELP
- What 2nd plane with retracts and flaps are good?
- Sane engine choice?
- Another First Flight Story
- Prop Selection
- WOHOOOO!!! Landed 3 times today!!
- TAIL DRAGGER FOR AN OLD BEGINNER
- Installing and wicking hinges
- I think I am in the right spot for help!
- What are some of the best running engines in the .40 to .50 rangr?
- O.S. .46 vs. Evolution .46
- 1st Kit.....Sig Somethin Extra?
- Covering wrinkles...
- Too Lean
- Loose aileron??
- SomeThing Extra Maiden Flight
- I flew for the first time This Weekend!!!
- photo under your name
- kadet senior tail fin
- SIG Somethin' Extra
- Which Low Wing Sport plane???
- Online HS that carries Midwest Aerobat
- Question about tubing over cleavises !!!!!
- Were are all the R/C chat rooms
- In-flight jitters
- First time using a retract servo, need help.
- Best trainer?
- prop size for 02 48 surpass?
- Started Avistar Build some questions..
- Help Starting .40 SuperStar
- A Leaky Needle valve on OS 40 FX???HELP!
- Early Christmas, YIP, YIP, YIPEEEEEEEEE!!
- Futaba 4vf
- Monokote repair on my old bird
- FREE - Giving Away - 2 Planes & stuff
- Seagull Models's Extra 300S
- beginner looking for help
- skyward 40
- Let's meet the new guys!
- Isolated but learning slowly
- Nitro Capitol Trainer or Avistar 40 help
- Midwest Aerobat or Eagle II?
- water world
- Undecided in which direction to mount engine
- Could be a good flying day!
- Balancing a prop
- tell me your story
- H9 Alpha Engine Tilt question
- Help me pick my next plane
- Cermark LCD Power Panel Problem..
- Lost Bigginer
- Does anyone have the Tower Flyer for Sept 03?
- Aileron connection problem....oops
- multiplex Moviestar
- nose heavy / tail heavy
- Bad Virbration
- Plans For a field Box
- Made a huge building error, send help.
- Flying at a different field was a whole new ballgame...
- Better of the 2 Rascals?!
- SPINNER BACKPLATE
- Monocote Question !!!!!!!!!
- second plane?
- aircore trainer or a alpha?
- Thank you to all the helpful types.
- Hello!
- extending antenna when testing??
- Is Ultra Stick 40 Good 2nd Plane?
- Chompin' at the bit for #2
- Hooked two newbies
- Air Filters
- beginner...starting with a patriot!! i love it!
- Rubber Bands or Bolts?
- Rich, Lean, Needle Valves?
- Newbies Bi-Plane
- Tach Readings (12x6 results)
- Where are the Pre School Beginners?
- Goldberg Eagle II hatch
- First time pilot and builder
- Question on Saito 100 Spinner and Prop Nuts
- SIG KEDET LT 40 QUESTION
- New airplane questions
- metal control rod threading tool
- Sig rascal trainer question
- Firewall Repair!!!
- Muffler Baffle Removal??
- A Bit more power in an Avistar!
- Sig Trainer question
- Balancing Act
- Need any Kindling?
- Flew today, after an 8 year "break"
- How to make a Fighterbird into something EXTREME!
- Questions about SIG LT 40
- speed control question
- Did I do ok guys?
- How much extra weight can my airplane safely cary?
- Retract servo
- My first engine cleaning experience
- Beware DANGER !!!!!!!!!!!!
- pull pull system
- Help me to decide
- Engines?
- just some thoughts
- HEEEEELLLLPP!
- Ok, NEXT question...sorry. (Carb settings)
- Information on the Kitty Hawk?
- beginner starting with a patriot...great training plane!!!
- Check out equipment at club in WBoro, Mass
- First Flight was a success! Slowsticks are awsome!!!
- First SOLO Landing!
- a bad bad thing!
- Goldberg Eagle 2 Arf
- Will my Engine run after a 15 year storage period? I'm concerned about safety!
- Noob tyring to get in the air K&B .40
- RCU Members Thank You
- Needle Extension OS-46FX
- Is my Radio Gear Legal? Please help...trying to get back into the hobby after 15 years!
- Trainer List
- Wut's a gyro?
- First Solo Today
- A quick question about my GP PT-40
- when to clean engine
- back into it after 12 year absence
- It wants to fly backwards. Problem Solved!
- E-bay
- A few newbie questions
- Engine Life Expectancy?
- killer vee anyone?
- OS .61 FX Engine problem
- Prop for UCD 3D and TT 46 Pro?
- Prop Selection ?
- U-CAN-DO 3D 46 From Avistar
- Kadet LT-40 - From Tricycle Gear to TailWheel
- 12 volt "Gel" battery
- Beginer Advice needed..
- Engine starts right up after 16 years
- Eagle 2 ARF & 4 Stroke Engine
- tuned up
- New here... question about first plane
- Recommendation
- Moving On!
- Duct fan for gas engines
- Glow plugs?
- When I take to the skies
- making hinge slots
- Thinning epoxy
- Weed Eater
- Sharp turn just before leaving ground
- When is a beginner not a beginner??
- FRANCISCAN HOBBIES IN SAN FRANCISCO
- feild box
- Questions About My First Low Wing !!!!!!!!
- 4 stroke x 2 stroke
- Evolution .45 alpha trainer engine runs backwards
- Need to switch channel, will any work??
- Sig Somethin' Extra: a good second plane?
- Futaba Receiver Numbers
