View Full Version : Beginners
- Hi guys, long time no see!
- Sig Kadet EP42 ARF
- How does it roll
- Modeltech Mini Magic Extra 20/480 ARF
- I almost got killed today!
- First Solo...Yippeeee....!!
- crashed my trainer this morning!!!
- Transmitter?
- Battery help
- High/Low Rates or Expo?
- Pinning Hinges?
- Painting propeller tips
- radio choices
- monokote
- Help starting a Webra .50
- Clubs
- GP Extra 300 .40 size what engine?
- fuelproofing with thinned epoxy
- Field Stand
- Is this a good 1st model???
- Newsletter assist
- help with engine after crashing my 1st plane.
- Plans for a trainer
- Expanding my interests in RC to planes
- My first flight!
- Increase/Decrease Throw
- uproar balance
- HELP! Fuel tank?
- What can i do
- Is this anygood>?
- The Newbie Tip Thread
- New to the hobby
- mustang 40 arf
- take off tips ???? in flight trim ???
- Aerobatic stuff you can do with a trainer.
- starting an inverted engine
- Superstar ARF with Monokote Wrinkles
- How important is balancing the prop?
- Balancing Laterally?
- difference between sportster and acrobatic plane
- setup questions, basics......
- Recommendations for a noob?
- When do you get a second plane?
- small plane
- Nexstar questions
- antenna question
- Florio Flyer Stunt Wagon Build
- Trim Help!
- New to flying, what airplane do I get to start.
- how did ya'll do first time alone
- Flywheel removal
- TT pro46 muffler question
- A big hurrah for Shakes268 :)
- My Progress Now ya happy?
- P51 Mustang RTF by Parkzone
- Radio question FM/PCM
- Fuel question
- Fixing ailerons
- Replacing clamp style motor mounts
- CFIT!
- Evolution 46 Break In
- Mile High Flying
- Old Trainer Question
- For the experienced builders only
- Finally did it!
- Help how to set up vtail airplane
- thoughts and prayers
- can I use a bigger engine?
- Fuel/oil soaked balsa - how to clean?
- Fuel Tank Size
- Help Plane has the jitters
- Is the AMA really worth it?
- Enya 40 SS BB carb
- Aluminium Spinner Sizes
- Newbie..
- Flew the Kadet and I did pretty good!!
- Breaking in an OS LA 40
- Help with Engine Problems
- GWS A10 for beginners?
- Futaba Conquest???
- VMAR Hornet Wing
- Brand new to this
- woohoo I'm finally back
- Tail Heavy Alpha
- .40 Trainer with Flaperons
- How to scare yourself AND gain confidence in your plane.
- take C of G when wet?
- flying solo - shakes
- Receiver aerial length
- FUEL TANK TROUBLE
- Great Planes Easy Fueler Valve Glow
- Oh happy day
- Flair Giles 202 .120 on OS91
- Bond strength: 15 vs 30 minute epoxy...
- Ripmax Xclaim
- weight of airplane
- Servo Crosstalk - any ideas?
- Question on alerion?
- To fiberglass, or not to fiberglass
- Problems with Tiger Shark 46 Engine
- Best Scale Trainer for 91 4stroke
- A REAL BALANCING PROBLEM
- GP Stuka A.R.F. build
- Help Identify this plane??
- VMAR/RichmondRC, I'm Kicking myself now
- Looking for a flying area
- Some days just aren't meant to be....
- I'm a Flyer not a builder
- servo question
- Adjusting main wing
- phoenix sea bee arf build
- Heat and Humidity on Engine Performance
- RCHobby.co.uk = Awful
- Electric Planes
- I just HAVE to share the feeling...
- balancing tiger 60
- Best online hobby retailers?
- Hobbistar 60 arf
- covering a repair job
- .25 plane
- setting up rudder aileron mixing ?
- O.S. .46 fxi question
- Free airplane (no engine/RX) in San Diego area
- What is this for?
- Pushrod system
- nitro temp. ques.
- Need info. On the RaidenTech Cessna 4channel
- Throttle Cable
- Solo certificate
- Goop Hand Cleaner Wipes for planes?
- 1st Glow Plane opinions
- Flaperon Setup
- My first succesfull solo flights
- What is a great electric trainer
- Repairing broken lading gear on trainer
- Ran an O.S 40 LA for first time and...
- Battery Charger/cycler recommendations?
- AX 46 leaking front bearing
- wing halves on trainer
- FM or PCM ?
- heli engine into planes.....
- U-Can-Do 3D EP
- OS 40 LA is stuck up....
- RCU Member Flyboy involved in Plane Crash
- New begineer plane?
- stuka almost done
- SERVO PROBLEMS
- Plane seems nervous in the air.
- Need input on next plane
- Plane Storage
- Great Planes T-Craft for a Second Plane??
- Flight training regiment?
- Another spinner question
- ANY TIPS FOR MY NEW PLANE
- Spinner for EVO .46 NT
- NEXSTAR ARF .....PROBLEMS...PROBLEMS
- Wing joining tubes
- Glow Plugs
- Seeking comments on 3 airplanes
- SUPER XL "S" 61 ASP MAGNUM
- Wing snapped in half, repair question...
- 2nd plane for newbies
- Death of a 4*
- Soloed today!
- We've all been there...
- Just ordered a frontier 40...
- Funny thing happened today
- who went up wings and wheels this week??
- i just bought my self a free flight plane
- new pilot/structural failure
- Sportsters aviation
- Fire in the aircraft
- Autopilot CPD4
- Tower Hobbies RTF Traine problem
- my plane and field
- os 52 engine problem
- Always carry a spare.....
- Learn to Fly with a P-51 Mustang Thanks H9
- fire
- Global Right Flyer 60H II ARF
- plugging a hole in the firewall
- Tiger 60 ARF vs... what?
- ORDERED MY NEXSTAR
- smoke pump identification, and help
- Solder Clevis
- Easy cheap plane?
- Ultra Stick 60 as Second Plane
- Spinner for evolution .61
- How do you get your models/supplies?
- Help with potential purchase
- metal to metal contact causing interference question
- Real disappointment yesterday
- Prop Choice
- Will these work for tourque rods?
- Welcome Begginers!
- Goldberg Anniversary Cub as a Trainer?
- Starting a gas engine...
- Homemade Nylon Pushrods, possible?
- Ailerons on beginner plane??
- sanwa tx and multiplex RX?
- V-Tail configuration.
- Fule Tank
- total noob here
- nexstar question
- Second Radio System???
- First plane to learn how to fly
- Midwest Aerobat Maiden flight
- Difference between PCM and FM??
- 4-stroke to 2-stroke....
- What Do you guys think? (Batteries)
- first acrobatic plane
- witch is beter
- Tricks/Tips for Covering Filets
- I Guess We Didn't Scare 'Em Too Badly!
- SkyMax 40
- Progress Report...
- Looking to get in the air
- Prop balance
- spinner and prop install help!
- Replacement transmitter antenna for 7cap?
- OUCH!!! Ugly Stick has died
- NexSTAR 46 v. Hobbistar 60
- engine question
- Got my avistar back in the air!
- When your gut tells you to land....LAND!
- O.S. 40LA and Avistar Question
- Good buy in Shenzhen, Guangzhou, China?
- A basic engine question!
- Back in the saddle again....
- START 40, EVOLUTION 2
- Bungee Cords
- antenna routing great planes big stik
- Batteries and Voltages
- 6V vs 4.8
- Best prop for.....
- Dual Batteries?
- Help building a flight box
- what would you do?
- Maiden flight of the ElectroStreak
- Engine wont go full throttle
- fuel out of muffler!!!!
- is this good for a first plane
- AVISTAR TIPS
- I got a free plane...
- What would YOU do to this !!! (picture)
- how long can you charge a radio?
- ENGINE TEST Bed
- may be a silly qeustion but why...
- NexStar Arf
