View Full Version : Beginners
- Cradle for planes
- Polarized Sunglasses
- Contest for Micro Flyer RC Electric Airplane
- Top Flite Woodpecker for covering?
- Magnum XLS 46---good engine or waste of money?
- U bended fuel tube, anyone had it before?
- Transmitter and receiver questions.
- REMOVING PRE-APPLIED STICKER
- Balsa, SPAD, and foam- comparison?
- battery time limit
- Futaba radio problem...
- Engine Problem
- Rejoining Wing Halves
- First "real" airplane
- Saito Steaming after shutdown
- Second flight!!
- Help choosing a second plane after crashing
- Saito .82 Normal RPM range
- What RX to put with this radio?
- Remove Muffler Cone Baffle = More Power?
- Glow plug
- mounting engines
- FLYING CLUB -HOW TO
- What's the advantage of dual aileron servos?
- radio/battery problem?
- RX/TX Question
- Fuel line connectors
- Uneven aileron throws.
- Airtronics radio battery dies quickly (help,why)?
- Help Me choose a park flyer
- Windy = nose up?
- New VS. Used engine
- Receiver Question
- What would be a good choice for a remote glow?
- How did your flying go yesterday? Anything exciting?
- NITRO MODELS 51" P-38
- Looking to get a plane what should i start with
- Battery choice
- Mounting 2 strokes upside down
- Selling: Ebay vs. here
- Aileron Mixing
- A question about tail wheel assemblies
- What glue for sheeting???
- Hinge installation?
- Preflight Check
- Ready for 3-channel?
- Maiden flight
- QUestion about 2 stroke aircraft engine temps
- Sig 1/6 WACO
- I'm Blowing Hot & Cold between Nicd & Nimh
- Recomend a first tail dragger
- Older Saito FA80 help.
- What tank size?
- Scratch built Ugly Stick fisrt flight video
- New picture format
- Newbie advice from a newbie.
- Correct fuel tank installation--help
- rx crystal change
- FEATHER SERVO GROMMETS
- Know anything about this trainer?
- Stripped Screw
- Need suggestions for repairing my new plane
- What size plane for an OS 10?
- Saito .82 Spinner Adaptor Issue
- Painting Ultrakote
- Dynaflite butterfly CG
- First RC Plane/Kit Finished (LT-40)!!!
- Four Stroke vs Two Stroke Fuel Differences
- Lets try this again. What plane is this?
- Buddy box compatibility
- SIG Cap 231
- Stormlauncher motors die
- Dean's 2-Pin Ultra??? for SIG EP42
- C.G. position: with fuel or not?
- NooB
- What ESC,motor etc.?Pics
- Parkzone T28 Trojan: A new "best" electric trainer?
- Best 60-90 size palne for 3D
- moving C.G. back......help?
- servo connections
- Reciever Battery
- G4 vs. AFP flight sim questions...
- How's this for a beginner to start out?
- BMFA registration form
- 2nd Plane, When?
- Question about fuel system
- Strong enough?
- Small yard, small plane?
- Aero ace bipe help
- Nexstar Steering
- Old Fuel + second tank = no start?
- Is R/C airplane flying a Hobby or an OBSESSION??
- Thinking of swapping Tx crystals on your own?
- Buddy boxes
- My Edge has a strange growth on top of it....
- Spinner problem
- Gee Whiz BEE
- Engine Mounting-can someone explain thrust?
- The wind is calm
- Looking for an instructor in the Ridgecrest, CA area.
- Would this be an ok trainer plane?
- Greasers vs. electric
- Could you use a heli motor in a plane ?
- MOST BANG FOR YOUR BUCK--COMMENTS
- Engine Help!!!!!!!!
- Ugly Stick built from DXF free plans
- Futaba 7CAP, Hitec rcd receiver,battery,servos, Help with how to hook it all up PLEASEEEEEEE
- rough idle question
- Taxing.. Look out!!
- Good .40-.50 engine
- Spinner / cowl
- RADIO HELP NEEDED! HOW MANY CHANNELS?
- Cowling halves
- Does CA eat plastic?
- Need help setting up servos for elevator
- Do sizes of gloplugs make any difference?
- Does a fully Synthesized Tx work with a crystal fitted Rx?
- How many hours can I put on a .46 before a rebuild?
- Is a flight sim really necessary?
- First Flight
- TO ALL NEW FLYERS-SEE PROP BITTEN
- Buddy box question
- GlideScope Radio Controled Aircraft Co.
- Stuck in the 80's!
- Need help with this repair...
- Where can I buy a decent used 6 channel computer radio?
- Beginners first build
- HELP NEXSTAR BLUEPRINTS/PLANS!!
- metal gear servos
- AMA question
- First proper plane
- 4 STROKE VS. 2 STROKE!!
- Best First Radio?
- HOW LONG WILL A NEXSTAR FLY FOR ON AVERAGE?
- IS THERE ANY PLANES THAT WILL FLY LONGER THEN 20 MINUTES?
- Complete RC noob needs help
- Brushless conversion
- Engine Question
- Servo Questions
- hey, i have one question about trainers.
- Dumb thumbs = splat.
- CA protection
- Spinner Size?
- Fueling station
- how offten do you find your fingers in spinning prop?
- Rocking the boat
- free flight?
- On my first flight I...
- Do you have to have AMA insurance and are there restrictions on where you can fly?
- Trainer that would eventually lead up to flying a Piper J-3 Cub
- How dumb would it be to start flying a PTS without a trainer?
- Fun with Motors
- 30 min epoxy
- What do I need for this repair?
- I'm a big idiot!
- What servos go with what Receiver #'s on Plane?(please help)
- Building Eagle 2...What Engine?
- Sig four*40 kit
- Anyone From Wayne Modelers?
- brand new pilot would this be a good plane to learn on?
- Component sequence hookup
- Way nose heavy
- questions on hinges and mounting engine
- CHUNK OUT OF ENGINE - PLEASE HELP
- ACETONE eats Plastic
- Flight Leasons
- My first plane and solo experience --- F27-C Stryker
- lanier explorer.....here we go again
- Propellar spun off gp-42 engine? Over-rev damage?
- Heat gun/ iron ?
- lithium ion question
- Engine Question
- Tx trouble
- Adhering covering to fuel-soaked wood?
- What radio to consider getting?
- What do you use ???
- mixing fuels
- windex method
- Color schemes examples - websites....
- TRAINER FUEL & glow plugs
- obrienhobbies.com - anyone have their phone number??
- Dx7 receiver
- game cube battery
- Fuel purchase
- Tiny air bubbles in fuel line
- Old Futaba AM radio
- Futaba Transmitter / airtronics recevier
- What position should be of fuel tank on tail dragger or tricycle type
- Alittle update
- Best way to ship a plane - 60 size
- What prop shoud I run?
- Replacing starter cone
- Med wind ducked fan model????????
- PCM or PPM
- Fuel Tank Setup
- Super Skybolt ARF
- Fuel Questions.
- Is a 6 channel reciever enough?
- Reciever slots
- .. still on the ground.
- parkzone planes
- Most popular manufacturers
- Stalling issue - too lean or too rich?
- Need advice on servos and reciever
- Choosing a spinner
- Hobbico Electristar
- What plane to get to fly in high winds but slowly
- Where to get parts?
- Cover foam-core cone with covering?
- inverted engine issue
- Help! Mini storm launcher
- Whats your favorite brand of CA?
- How to find your max rpm?
- Rascal 40 - Need electric conversion..
- Soloed my Tiger Trainer!!
- Solo today
- Purchase List
- Looking for a good 12v charger for vehicle
- Sapac T34
- Hinging thin control surfaces
- Removing wrinkles
- Thank goodness for Instructors
- OS 1.20 AX bearings
- World Models LA Racer
- Super Tigre GS-40 Throttle UP Problem
- Discharging batteries
- Plug question
- joss stik 60
- Paint
- Trainer plane economy pricing
- PRO PEAK INSTRUCTIONS
- RX SPEKTRUM QUESTION
- RX battery question/getting back into hobby
- Does aluminum-to-metal cause glitching?
- Four Star 60 Reborn
- Engine Question
- Need Advise on Aileron linkage
- Clamping help
- measuring engine thrust angle.....??
- sloppy builds vs. flying
- Alpha 60
- I Killed it !!!!
- LT-40 aileron alignment problem
- help selecting servo size!
- Releasing Thread Lock?
- Its here!!!!
- maiden my alpha 40
- Maiden.
- Stupidity leads to aircraft crash
